Re: Radiator leaking ------ HEELP!!!!!!!!!!!!!!!
Posted by Ludwig on February 07, 2003 at 08:43:24 from (141.154.116.114):
In Reply to: Radiator leaking ------ HEELP!!!!!!!!!!!!!!! posted by BIG JOHN on February 06, 2003 at 17:20:19:
Since the others say it'll probably work I'll point out one good aspect of using it in a thermosphin system.
No thermostat to seieze.
Just in case anybody reading this decides to try it in a pressureized system, note that you should take out your thermostat. Run the stuff. When the leak is sealed flush, flush, flush the system, then replace the thermostat.
Otherwise you will sieze the thermostat. I've been down that road enough times to know its a bad place to be.
Post A Followup
: Re: Re: Radiator leaking ------ HEELP!!!!!!!!!!!!!!!
