Re: H belly pump capacity
Posted by Steven@nd on February 07, 2003 at 10:06:39 from (12.23.184.77):
In Reply to: H belly pump capacity posted by KevinSC on February 07, 2003 at 06:55:21:
Yes, 30 weight non-detergent oil is what is recommended and will develop more pressure than Hy-Tran. I run Hy-Tran in my belly pump and it has plenty of pressure.
Personally, I would go with the Hy-Tran because 30 weight non-detergent oil is hard to find around here. (NOTE: regular oils are detergent, you cannot use them because they will foam.)
Post A Followup
: Re: Re: H belly pump capacity
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
