Re: 6 volt to 8 volt?
Posted by IH Man on February 07, 2003 at 16:38:28 from (209.240.198.63):
In Reply to: 6 volt to 8 volt? posted by Ken on February 07, 2003 at 14:06:10:
I have recently changed the battery in my 1951 IH "M" to 8 volt. When it would get warmed up after running a while the 6 volt just would barely turn it over. The engine has only 80 hours on it since rebuild and I assume tighter clearances after the engine heats up makes the starter work harder. I purchased an 8 volt battery from Tractor Supply Co. store and installed it. whatever model farmall you install an 8 volt into, you must adjust the voltage regulator to allow the generator to put out at least 9 volts. Most delco regulators are two contact type. One set is for voltage adjustment. It has a spring on the side of the contact and a phillips head adjustment screw. By turning the adjustment screw clockwise it will increase the generator output. You must hookup a volt meter to the battery, start the engine, warm it up and then open the throttle wide open. Slowly adjust the regulator screw until you read 9.0 to 9.5 volts. Be careful with your screw driver, ideally insulate it by wrapping it with plastic tape to keep from accidently from shorting out the contacts. Also be very careful in removing the regulator cover, keep dirt out of the contacts and reinstall the same way it came off. Light bulbs can be a problem if you run lights often..the 6 v bulbs don't like 8 volts for long duration. I use my "M" for pulling, so it isn't a daily or weekly work tractor. Some guys I know that have a "C" have run it for years with an 8 volt battery with no problems. Hope this helps...
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
