Re: splitting a 1206
Posted by IHBRAD on February 09, 2003 at 06:11:15 from (205.188.209.78):
In Reply to: splitting a 1206 posted by Bill on February 08, 2003 at 14:13:00:
You will need to make a stand that will bolt on to the at the speed transmission since you will be splitting the speed transmission from the rearend. It will have to handle alot of weight so BECAREFUL. Also make sure you put a stand or a block under the drawbar on the back cause the rear will have a tendancy to want to tip back. I am collecting 1206 Serial numbers and general location.Would you mind sharing yours? Thanks
Post A Followup
: Re: Re: splitting a 1206
