Farmall Tractors Discussion Board
Re: Re: Re: H Carb Rebuild
Posted by The Red on September 06, 1999 at 03:34:16 from (12.75.196.46):
In Reply to: Re: Re: H Carb Rebuild posted by CBrown on September 05, 1999 at 19:01:29:
If its sheared at the bottom where it is threaded into the carb body, you can drill it out. Just make sure you don't use to large a drill bit. I successfully drilled out one when I was rebuilding the 51H carb last May.
Post a Followup
: Re: Re: Re: Re: H Carb Rebuild
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
