Char Lynn crank pulley
Posted by Dave in MN on February 09, 2003 at 22:26:14 from (205.188.209.78):
Pulling apart the MTA to work on the engine and noticed a problem. The crankshaft pin had ground its way halfway into the PS pulley. The pulley was so loose I could turn it by hand with the pin still in. Is there a better way to mount up this pulley, or should I just get a new one and mount it up the same way?
Thanks in advance.
Post A Followup
: Re: Char Lynn crank pulley
