Re: 1486 Cab windshields
Posted by BERMUDA KEN on February 10, 2003 at 05:31:24 from (64.73.6.160):
In Reply to: 1486 Cab windshields posted by JD on February 09, 2003 at 14:24:04:
IH used two different side opening windows on the 86 series tractor cabs. You need to know the CAB serial number, NOT the tractor serial number to get the right one. The CAB serial number is stamped on a metal plate near the hyd levers on the RH door jamb/frame.
Once you have this number, any IH dealer can get you the correct window glass.
Post A Followup
: Re: Re: 1486 Cab windshields
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
