Re: Need help identifying wheels
Posted by Bill Smith on February 10, 2003 at 09:10:20 from (63.147.130.111):
In Reply to: Need help identifying wheels posted by Bguy on February 10, 2003 at 08:42:04:
Not up on wheel casting numbers myself, but sounds real likely that they are F-20 wheel's. F-20's had a hubbed axle that required a bolt on (not clamp on) wheel. They were 6 bolt I believe, and 36" was the most common size for a rubber tired F-20. The F-20 and Regular would interchange wheel's but were probably a little different in style from factory. The smaller F series tractors and most, if not all of the letter series had clamp on wheel's. The F-30 likely had a wider and or taller wheel that would of been somewhat different than the F-20 in some way or another. Unlikely for the F-20 and F-30 to have the same wheel but don't know that for an absolute fact. If your wheel fits an F-20, it will fit a regular as well, but I don't think rubber was an option for the regular from factory. Wheel will bolt right to the axle and won't need bolt in hubs since that is part of the axle.
Post A Followup
: Re: Re: Need help identifying wheels
