Re: HELP...TIRE CHAINS QUESTIONS
Posted by Jason on February 10, 2003 at 10:21:46 from (12.33.196.233):
In Reply to: HELP...TIRE CHAINS QUESTIONS posted by Jack on February 08, 2003 at 15:26:00:
Not real sure how to know exactly, but if you use the overall length of 14'4" (172") and plug it into the equation for circumference of a circle:
C= (3.1416) x (Diameter) and solve, you get
Diameter (in) = Circumference / 3.1416 and then
Diameter = 54.75" or a 4'6" tire
Could do the same for the other side (43.29") and that should get you close. Course those are EXACT numbers, your going to need a few inches to get the chain together on the tire. Don't know if method is correct, so if someone knows another way that is more accurate, please advise.
Thanks, Jason
Post A Followup
: Re: Re: HELP...TIRE CHAINS QUESTIONS
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
