Re: Farmall H Transmission Shift Lever Question
Posted by Larry on February 10, 2003 at 18:19:05 from (216.37.23.88):
In Reply to: Farmall H Transmission Shift Lever Question posted by mike in PA on February 09, 2003 at 23:57:50:
I have an H and a 350 that both had shift lever problems. Made a new 3/4" shaft from a #8 bolt and drilled a 1/2" hole in it. Made a new 1/2" shaft to substitute for the 7/16" shaft from a #8 bolt. Drilled out the shift tower to 1/2" and reinstalled the shift lever. Installed 2 5/8" drive plugs that cost .30 at the Auto Parts Store. This made the shifting mechanism good and tight and worked fine.
Post A Followup
: Re: Re: Farmall H Transmission Shift Lever Question
