Re: 1948 Cub Power
Posted by Phlogiston on February 10, 2003 at 19:23:48 from (65.129.80.112):
In Reply to: 1948 Cub Power posted by jdboy on February 10, 2003 at 19:20:53:
Your Cub will have plenty of power to handle any equipment made for it after the rebuild. Later Cubs had a larger carb., a different cam and domed, aluminum pistons. I think the head was a bit different too. Anyway, the rebuild should do it.
Phlogistin
Post A Followup
: Re: Re: 1948 Cub Power
