Re: leaking fuel tank cap
Posted by Bill Smith on February 10, 2003 at 19:27:28 from (63.147.130.36):
In Reply to: leaking fuel tank cap posted by Craig on February 10, 2003 at 17:30:59:
I had the same problem, but not with an A. Most gass caps have a seal/gasket that is suppose to fit tight on the neck of the tank when gas cap is put on and turned. Two things happen here. The seal/gasket gets thinned out and dried out and cracked and brittle and what not after years of use. The other thing is the metal tabs on the cap and the metal it slides against on the tank wears down after years of use. Both reasons will cause cap to fit somewhat looser than it needs to be and allow for the leak. Is what I did is custom made my own gasket to put in the cap. Made it a little thicker than perhaps what the original one was to start with. I used the gasket sheets that you can get to cut your own gasket out, that you can get at most parts stores. To make it thicker I simply put more than one layer in for the gasket. One cap I think I put three gaskets in it. It fit real sloppy when I started. All caps that I re-did turned out fine. They fit tight and did not leak. You might want to use a different material than the paper type gasket sheet. Not sure how long it will last and what not. The way I figured it, it was a cheap fix and can be done again if needed.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
