Re: MW hand clutch
Posted by Michael Soldan Hmmmm... on February 11, 2003 at 06:11:24 from (216.46.130.37):
In Reply to: MW hand clutch posted by Larry on February 11, 2003 at 03:15:16:
Hmmmm, Larry, I am not 100% here but a friend of mine has an M/W clutch assembly in a box that was on his H at one time and was taken off. He plans to put it back on to restore his H. The left side brake comes off and the shaft(Differential shaft) is changed with the M&W components..the size of that shaft is where I am hung up..an H and an M the same???..I doubt it..as to its value there are a series of plates in the assembly and if they are worn,rusted or somehow damaged I wouldn't want to invest a lot in it unless I knew it would work satisfactorily...I understand there is a supplier of these discs and components but it could get real expensive if it isn't already in decent shape. I have probably raised more questions and answered few but these are considerations for you to make..good luck from Mike in Exeter Ontario
Post A Followup
: Re: Re: MW hand clutch
