Re: Farmall A Implements
Posted by Dave BN on February 11, 2003 at 15:41:00 from (205.188.209.78):
In Reply to: Farmall A Implements posted by Greg Miller, Cornland, Illinois on February 11, 2003 at 10:57:51:
Sorry, no picture. In general, you need to remove both drawbars. Rear lift mechanism bolts to holes in final drive housing above where the rear drawbar was bolted (I think you can use the same bolts and nuts that held the rear drawbar on). The thin bars bolt to the axils using one of the fender bolts. The lift lever bolts to the floor pan by the operators right foot and the lift rod runs under the seat to the rear lift. The rest of the parts bolt to the front of the tractor and I think the plow beam hooks to the "big spring". Hope this helps a little. Try the link at the top left of the page for manuals to get a book for your plow. Good luck. Dave.
Post A Followup
: Re: Re: Farmall A Implements
