460-U hydraulic trouble
Posted by Josh on February 11, 2003 at 17:54:34 from (166.66.137.85):
I have a 460 utility with a #50 loader on it that runs off of the tractors hydraulics. About 2 weeks ago it was cold weather and stayed between 10 and 30 degrees for 2 weeks. I started the tractor once and noticed the loader wouldn't work at all. I figured it was just the cold. It was up to 45 last week and i started the tractor and hit the hydraulics and the loader worked. i only picked it up about a foot and then shut it off. This week it is below freezing and i needed it to move manure. The loader would come up but only very slowly and it wouldn't dump at all. It will also only pick up if the tractor is idling. If it is run fast the loader will drop back to the ground even if the lever is in the lift position. the power steering and fast hitch will not work either. Oil came out the plug in the side of the transmission and i added a little hy-tran just to make sure but no effect. what could be wrong? I tried letting it warm up for about 30 minutes but it didn't work. any ideas? Thanks.
Post A Followup
: Re: 460-U hydraulic trouble
