Re: 560 implement size
Posted by georgeky on March 29, 2009 at 08:15:02 from (64.12.116.73):
In Reply to: Re: 560 implement size posted by Bob O2 Martin on March 29, 2009 at 07:48:19:
Same here. It ain't happening with a 2520. Late into plowing season the 2520 I had would not pull 3 in sod ground.
The one I seen in NE was plowing bottom land in milo stubble on the Little Blue River. He was doing a fair job so I figured the ground must have been loose.
