Re: Re: Re: Getting ready to change the oil on my 'H'
Posted by Kelly C on February 12, 2003 at 10:31:18 from (63.171.43.140):
In Reply to: Re: Re: Getting ready to change the oil on my 'H' posted by Gary The Rookie Farmer on February 12, 2003 at 09:40:53:
#1 Do not change wile engine is running.
#2 Remove oil filter base drain plug and allow to drain completely
#3 Clean filter base to prvent dirt from dropping into the base.
#4 unscrew and remove the retaining bolt.
#5 Lift up and remove the case.
#6 Remove old element.
#7 Wipe out base and the case with a rag dampend with kerosene
#8Install new filter as follows:
(A) replace drain plug in filter base and install new element.
(b) inspect the small metering hole at the treaded end of the oil retaining bolt and make sure it is not plugged.
(c) make sure the gasket is in good condition.
reinstall the cover.
There are 2 sizes that fit a H depending on the year ( sn#) of your machine.
NAPA has both sizes.
Post A Followup
: Re: Re: Re: Re: Getting ready to change the oil on my 'H'
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
