Re: Re: Getting ready to change the oil on my 'H'
Posted by Michael Soldan on February 12, 2003 at 12:29:17 from (216.46.130.21):
In Reply to: Re: Getting ready to change the oil on my 'H' posted by Doug in OR on February 12, 2003 at 09:25:06:
I agree with you Doug, the only thing my experience has taught me is that for all that a pan gasket costs, pull the pan and clean it up , install a new gasket and make your switch to the oil of your choice. In most cases I'd bet that these tractors that we accumulate have been on non detergent oil, after all by the sixties and seventies detergent oils were the most common and the tractors were being used and worked..its not like we took one out of the fifties and suddenly give it a diet of 2003 oil technology. I had this experience with a B250 diesel and after removing 2" of black ooze from the pan I am using detergent oil and I have good oil pressure constantly, one of my H's is on detergent and I am assuming it was before, haven't had any problem with it either. Good luck to Gary the Rookie Farmer as well..Mike in Exeter Ontario
Post A Followup
: Re: Re: Re: Getting ready to change the oil on my 'H'
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
