Re: BF Goodrich tires
Posted by CNKS on February 12, 2003 at 19:03:06 from (207.178.96.211):
In Reply to: BF Goodrich tires posted by Dewa on February 12, 2003 at 10:51:39:
Unless you are very picky, or a purist, the tread design isn't going to make much difference appearance wise. This statement is not true if you are trying to duplicate the design that came on the tractor, in this case the Miller Tire catalog will show you the differences, and there are a lot of differences between brands. Miller Tire does not list a 12.4-38 BFG, but does list a 13.6-38.
Post A Followup
: Re: Re: BF Goodrich tires
