Re: 560 implement size
Posted by Hugh MacKay on March 29, 2009 at 08:21:50 from (209.226.106.53):
In Reply to: 560 implement size posted by John G. Hasler on March 29, 2009 at 06:10:18:
John: Anyone telling you they pull larger than a 12' tandem wheel controlled disk with a 560, is pulling a worn out disk. Personally if it were me I'd go 10' with 18" or 20" blades, you know your going to pull it in heavy conditions, cutting as deep as you wish.
I had a 10', pulled it behind my 560 or 656 for years. I also pulled a 12.5' vibra shank cultivator. Difference being I have seen the disk take me to 2nd gear, however usually 3rd gear, whereas cultivator was 3rd and 4th.
