Re: Loader to fit 1952 Super M -- wide front
Posted by jal-SD on February 14, 2003 at 15:12:11 from (12.17.66.90):
In Reply to: Loader to fit 1952 Super M -- wide front posted by Dan Larson on February 14, 2003 at 10:52:33:
If you can find a 300 series Dual, they are better, built a lot tougher. The 200 and 250 series (pictured below) were designed for lighter tractors, like an H. They will fit, but you'll tear them up w/bigger tractor. (Thats why so many are welded up.) A Farmhand F-11 will also work well, but they are a lot more "front-heavy" than a Dual. Both use a PTO pump, you'll get used to no live power, so don't worry about it. A Farmhand pump (even a wore out one) is WAY BETTER than a Dual pump. Best of both worlds is a Dual Loader w/yellow Farmhand pump! (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: Loader to fit 1952 Super M -- wide front
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
