Farmall H motor mount, HELP
Posted by Matt on February 15, 2003 at 09:48:20 from (205.160.214.212):
I have a farmall H sn 56591 and it has a rubberized motor mount between the engine and the frame rails in front. Every one I have seen has cast iron blocks between the frame rail. My problem is the rubber ones are shot and I would like to put in the cast mounts, but the bolt holes thru the frame rail are too close together to use the cast ones. Is there any place to get new (or good used) rubber motor mounts?
Post A Followup
: Re: Farmall H motor mount, HELP
