Re: IH300 U fast hitch float?
Posted by RAW in IA on February 15, 2003 at 15:55:52 from (12.216.217.196):
In Reply to: IH300 U fast hitch float? posted by Brett on February 15, 2003 at 13:58:47:
I believe on the 350 there is a pin in the bottom mounting bracket for the cylinder which could be put ina different hole to allow the hitch to float. This is not the cyllinder mount pin, but in the bracket it mounts on. Also, the lift arms had pins that could be removed to allow some float. The hitch had to float to let the plow and some other implements work right. i am not sure how muchdifference ther is on te 300 hitch.
Post A Followup
: Re: Re: IH300 U fast hitch float?
