Re: Tachometer for H
Posted by Red Rider on February 15, 2003 at 18:55:43 from (66.248.105.182):
In Reply to: Tachometer for H posted by Josh on February 15, 2003 at 17:32:30:
The first tractors that IH factory installed tachometers on were the 100 series tractors starting with the 300 through 600. You could add the parts off a 300/350 to your H and build you a bracket to put the factory IH tachometer on it. If I wanted a tach/hour meter on a IH gas tractor that had not come with one I wouldn't use the IH cable driven one. You can find a lot better electric Tach/hour meter and it would be a lot cheaper and easy to install.
Post A Followup
: Re: Re: Tachometer for H
