Re: F-20 cylinder sleeves-they won't come out
Posted by F-Dean on February 16, 2003 at 05:32:46 from (12.84.233.96):
In Reply to: F-20 cylinder sleeves-they won't come out posted by Tom in OH on February 15, 2003 at 12:55:19:
Tom,
How big a hurry are you in? I would seal the leak in place by capping the lower block drain to the radiator and filling the coolant area in the block with a thick mixture of radiator sealer. Let this set for 3-4 weeks and your leak should be sealed.
Post A Followup
: Re: Re: F-20 cylinder sleeves-they won't come out
