Farmall Tractors Discussion Board
Re: FARMALL 140
Posted by Pete on September 07, 1999 at 11:05:06 from (134.192.209.137):
In Reply to: FARMALL 140 posted by ROBERT NAQUIN/ED SIMPSON on September 05, 1999 at 20:42:54:
Hi there
I've got a 1951 Farmall 140 with hydrolics, (although mine does not have the connecting rods - no need yet). As far as I know, all 140s have the offset PTO (on the left side). This was called "Culti-Vision" b/c it allowed the farmer a clear view of the crops below. Be advised - this tractor does NOT accept the standard 3pt hitch...why? B/c the PTO is offset. I've been told people can "rig-up-somethin'-fer-ya" but that it is reccommended against. This is really something to consider, especially since a post-hole-digger can require a good deal of force - not always a good idea on a machine that is offset like the 140. If you can figure out a way though, let me know...i could use one myself. Bush hog...well, the trick is lining up the PTO shaft with the PTO on the tractor - again, good luck. Maybe a belt driven - pull behind model...if you can figure out a way, please let me know....I'd love one too
On the positive side, this is a fun little machine...I've got a belly mounted mowing deck on it, and am purchasing a snow / grading blade...
Pete
Post a Followup
: Re: Re: FARMALL 140
