Re: 3 point hitch kit for 560
Posted by Duane NC OH on February 18, 2003 at 03:41:30 from (12.34.57.49):
In Reply to: 3 point hitch kit for 560 posted by RedDieselMan on February 18, 2003 at 01:50:33:
i bought a 3 pt hitch for our 560 from a local dealer. it was a work saver. web site worksaver.com. i got the 2 cylinder lift one.
paid $750 for several years ago. once it was on we took hoses and ran them from the front hydrulic outlets and ran them to the back and mounted outlets off a 66 series tractor. now we had 2 remotes out the back and are the iso type.
we also put a wide front on it from a 656. works great. and we put a 301 combine engine in it from a 715. had a cracked block. it bolted right in.
good luck!
Duane
Post A Followup
: Re: Re: 3 point hitch kit for 560
