Re: Super WD9 Gas Starting Problems - HELP NEEDED PLEASE
Posted by Richard on February 18, 2003 at 11:42:38 from (205.188.209.78):
In Reply to: Super WD9 Gas Starting Problems - HELP NEEDED PLEASE posted by Clark Weaver on February 18, 2003 at 09:04:59:
Take the valve cover off,then move the compression lever back and forth. watch the rod that pushes the starting valves down. if they are not going down you need to adjust the lever. carb kits are $275. at bates.corp.com float and gaskests. Just because the float is moving doesn't mean its getting fuel. One more thing it could be is the butterfly valves in the intake manifold which work on trip lever when compression lever is moved.
Post A Followup
: Re: Re: Super WD9 Gas Starting Problems - HELP NEEDED PLEASE
