Re: Super A Sediment Bowl
Posted by SAm in NS on February 18, 2003 at 14:01:03 from (24.138.71.44):
In Reply to: Super A Sediment Bowl posted by Paul NS on February 18, 2003 at 10:44:55:
The air cleaner is on the left hand side of the engine towards the back. It is about 4-6" in diameter. It should have a smaller 1" (ish) pipe coming out of the top of it and extending through the hood. The pre-cleaner should be on the top of that pipe and should pull off (straight up). The bottom of the air cleaner is removeable. There is a clamp about 3" from the bottom. Undo the bottom and remove, clean it and refill with clean motor oil (due to the temp. I'd reccomend 10wt.). Hope this helps. SAm in NS
Post A Followup
: Re: Re: Super A Sediment Bowl
