Re: 460 STUCK
Posted by Andy Martin IE on February 19, 2003 at 05:13:18 from (12.86.246.44):
In Reply to: 460 STUCK posted by Tim on February 19, 2003 at 04:37:38:
I'd pull the plugs, squirt MMO in each cylinder and reinstall the plugs. Then let it sit for a week or more.
When you pull the plugs you may find the offending cylinder by a very rusty plug. You can often tell from the condition of the plugs if you should go ahead and disassemble the engine. A little rust on the plugs is OK but totally plugged with rust indicates it will never run without being repaired.
Then put it in 5th gear and try rocking it. If that does not free it up, more MMO and PB Blaster, sit another week.
If rocking does not free it up, I'd drag it and repeatedly engage and disengage the clutch. Tear up a little dirt. Both forward and backward. I've freed up many this way.
If it is still stuck, bite the bullet and pull the head to see what you've got.
Stay away from pipe wrench on the PTO or harmonic balancer, pry bars on the ring gear, and pumping grease into the cylinders under pressure and you will not cause damage to good parts.
Post A Followup
: Re: Re: 460 STUCK
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
