Re: International 340 Utility Questions
Posted by CATSKILL PETE on February 19, 2003 at 09:38:07 from (207.127.238.117):
In Reply to: International 340 Utility Questions posted by Brian Schmidt on February 18, 2003 at 16:40:13:
My answer about the pto is just an educated guess but here goes. The live pto is certainly possible, dollar wise is another question. The complete pto unit bolts into that blank cover on the back of the tractor, IF ,the tractor has the drive shaft in place under the transmission. You would have to remove the back cover plate. [drain tran/hyd system first] Look inside of housing and see if the shaft is there. It should be a splined stub. Maybe the quickest way to tell is to see which type of hyd. pump it has. If it has the 9gpm pump mounted on the front of the engine under the distributor,shaft is not likely. If it has a blank cover plate under the distributor then it probably has the 12 gpm transmission mounted pump. The trans. mounted pump drives off the same shaft as the pto so it is probably in place, and can be used. Hope answer didn,t confuse too much. contact me if more info needed.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
