Re: Re: Bon-ami in intake?
Posted by Dennis Garrett on February 19, 2003 at 19:41:25 from (64.12.97.13):
In Reply to: Re: Bon-ami in intake? posted by Greg(Mo) on February 19, 2003 at 12:54:25:
I have a Caterpillar Diesel engine serviceman's reference manual, for 5-3/4" bore 6 cyl engines, teh ones used in the D-8 Cat tractors in the early fiftys. On P.180, it discusses the use of "break-in powder" as a third method to hasten seatings of new rings to worn liners. "After assembling & starting the engine, loosen the air cleaner to allow a gap between the flange and the inlet manifold. Run the engine at about 800 rpm and allow the powder to be sucked slowly throught the gap into the engine. Use 1-1/4 teaspoons of powder par cylinder and then tighten the air cleaner, run at idle at 800 rpm for thirty minutes, and it is then ready for service" "this method of break-in has been used successfully when facilities were not available for honing or etching the liners. If first treatment was not effective, a second one may be."
Post A Followup
: Re: Re: Re: Bon-ami in intake?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
