Farmall Tractors Discussion Board |
Re: Re: Re: Need temp guage for 1949 Cub??????????
Posted by ltf in nc on September 07, 1999 at 17:32:20 from (206.228.213.238):
In Reply to: Re: Re: Need temp guage for 1949 Cub?????????? posted by Fred on September 07, 1999 at 06:56:19:
There should not be a problem as the hose is several times the diameter required to carry the flow. Think about the opening size in a thermostat. The theremostat body and the mechanism are a major blockage but operate very satisfactorily. Notice in my post that I did state to purchase a gauge set with a small bulb on the capillary tube. One final point, if there is a problem you would now have a gauge to alert you of the fault. If the tractor is not running hot before the installation it will not run hot due to the installation.
Post a Followup
