Re: Re: Cub - Regular ,Lowboy Difference ???
Posted by Harold H on February 21, 2003 at 07:59:14 from (207.244.60.124):
In Reply to: Re: Cub - Regular ,Lowboy Difference ??? posted by Lowboy sits lower on February 20, 2003 at 15:47:50:
On the LowBoy the rear axle drop housings are rotated forward 90 degrees which lowers the rear of the tractor. On the regular Farmall Cub they are mounted straight down to give high clearence under the tractor rear end. Shorter front axle height already mentioned.
Harold H
Post A Followup
: Re: Re: Re: Cub - Regular ,Lowboy Difference ???
