Re: Exhaust Questions for F-20
Posted by Bill Smith on February 21, 2003 at 10:30:15 from (128.242.4.59):
In Reply to: Exhaust Questions for F-20 posted by Dave in GA on February 21, 2003 at 08:42:37:
The origainal manifold for the dual fuel burning F-20 I believe had the larger exhaust outlet pipe. The after market manifolds and perhaps the original gas burning manifolds had a smaller exhaust outlet pipe. Originally with no muffler the F-20 had a caste iron elbow that shot the exhaust out to the side and didn't extrude out of the hood with much height. The original pipe I am sure had a set length and the elbow I believe clamped right on to that. It seems to me that the top of the elbow on an original set up was just guessing in the 6 inch range above the top of hood. It doesn't come out of the hood very far before it bends.
Post A Followup
: Re: Re: Exhaust Questions for F-20
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
