Re: 1950 H, which points to use
Posted by karl f on February 21, 2003 at 12:05:32 from (65.237.15.140):
In Reply to: 1950 H, which points to use posted by Robert in Md. on February 20, 2003 at 18:36:47:
just in case it is an aftermarket... mine has a vertical distributor made by delco--there's a small tag the prominently says "delco-remy" on it. those points are ez to find. they are the same as the ones in lots of tractors of the 40s and 50s. an IH distributor sits horizontal in this application. other aftermarket distributors may sit horizontal as well. you could have an IH distributor added as an afterthought, so it might be a different model than the H used as well..
good luck figurin out
-karl
Post A Followup
: Re: Re: 1950 H, which points to use
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
