Diameter of coolant holes in 560D block into head
Posted by RO on February 22, 2003 at 20:59:46 from (24.124.48.58):
Are the coolant holes in the top of the block on a 560D roughly 3/8 inches in diameter or are they as large as 5/8 inches. I took my head off and afterwards took some photos of the block. I did this because I live a ways from the tractor and I enjoy looking things over when I get home.
Looking at the photos, I thought I had about an eighth inch of rust buildup in each coolant hole. Today, I had just a few minutes and decided to check how hard the rust would be to remove. It appears that what I'd thought was a considerable build up, might be just the amount built up on top of the block where the head gasket circles are cut out for the coolant to pass through. Indeed, the actual coolant hole appears to be only about 3/8ths diameter. I couldn't spend any time to further check this today and thought someone experienced might be able to answer the question.
Post A Followup
: Re: Diameter of coolant holes in 560D block into head
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
