Re: Long term Storage
Posted by Shovelman on February 23, 2003 at 16:32:12 from (24.151.89.245):
In Reply to: Long term Storage posted by Bob(WI) on February 23, 2003 at 13:04:09:
Bob,
The other fellows have made good points.
Some of my collection is stored for long periods, and this is how I proceed:
Change engine oil & filter. Drain, flush and refill coolant. Used oil and anti-freeze can become acidic over time, so I prefer to change it and leave it in.
Remove the spark plugs and pour several ounces of motor oil (not synthetic) into each cylinder. Turn engine over slowly with the plugs out to distribute the oil. Install plugs.
Seal the intake and exhaust with rags/tape to keep out moisture and rodents.
I have had good luck with Sta-Bil fuel stabilizer, but I would drain the tank, lines and carb if it was going to be longer than a year in storage.
As Bill recommended, block it up slightly off the ground, but do not deflate the tires.
Apply a light coating of grease to the loader cylinder rods. I spray LPS or WD-40 on distributor (or mag), plug wires and anything else I want to protect.
Tarp the tractor, including the tires, to protect it from direct sunlight, bird droppings, etc. However, do not wrap it tightly, as you want it to "breathe" and not trap any moisture under the tarp.
Good luck,
Scott
Post A Followup
: Re: Re: Long term Storage
