Re: Long term Storage
Posted by Hugh MacKay on February 23, 2003 at 16:50:03 from (209.226.247.91):
In Reply to: Long term Storage posted by Bob(WI) on February 23, 2003 at 13:04:09:
Bob: After disagreeing with Bill, and I do like his suggestions other than those I mentioned. I felt I should be a bit more constructive. I bought a truck rear end and housing once, as I knew the one in my truck was less than healthy. I bought it for two reasons, price was right and it was in imaculate condition. I had no place convenient to store inside. I filled it right full to top with used gear oil. Turned pinion upward and placed a can over it. I had seen unused gear boxes turn rusty at oil surface in past. When it came time to use this rear end some 3 years later, I drained all the oil and it was still imaculate. If I were you I would fill all tractor gear boxes right to top with used oil. I would fill hydraulic system right to top. I would fill cooling system right to cover with sufficient strength coolant for cold weather expected. If tractor is diesel fill it full. If is gas I would drain completely and fill with diesel. The diesel will evaporate less and will also be less volitile. Best way to avoid condensation damage is not leave a space for moisture.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
