Re: Re: Re: Long term Storage
Posted by Bill Smith on February 23, 2003 at 19:08:31 from (128.242.4.59):
In Reply to: Re: Re: Long term Storage posted by Hugh MacKay on February 23, 2003 at 14:49:03:
I see your point on the fluids being left in. Both draining fluids and leaving full of fluid has advantages and disadvantages. The coolant for example, if left in and not circulated and after a certain point, the antifreeze started breaking down, would have to be checked periodically for its strength to insure that there isn't a freeze up. That would be avoided by draining. Fuel for another example gets real nasty after it has set for a long period of time. Kind of turns to a tar if left long enough. Evaporation or perhaps a fuel leak would put you back to 3/4 or 1/2 tank after long period of time wich leaving full wouldn't help much and could lead to a fire hazzard. Again a complete drain of the entire fuel system and minimal ventilation time shows some advantages. I guess it kind of boils down to whether you want to deal with sludge from fluids or rust from condensation when you get it out of storage. Before someone decides what to do I guess they should factor in there climate. If you are in the desert where there is no humidity you might want to drain all fluids, and if you are in a swamp region with high humidity you might want to fill everything up. And in between or up north you could probably go either way. I am not argueing but just seeing and agreeing with both sides of the fence here.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
