Re: Re: Re: '49 Cub compression
Posted by George Willer on February 25, 2003 at 07:24:38 from (66.242.44.50):
In Reply to: Re: Re: '49 Cub compression posted by EZ on February 25, 2003 at 05:13:02:
EZ,
My gauge will show somewhere around 90 PSI on a fresh engine...but that tells you more about the gauge than the engine. The important thing is how the cylinders compare to each other.
For diagnostics, a leakdown test can be even better than a compression test. It can tell you whether a problem is rings, intake valve, head gasket, or exhaust valve.
George Willer
Post A Followup
: Re: Re: Re: Re: '49 Cub compression
