Re: Farmall H missing
Posted by Bill Smith on February 25, 2003 at 11:39:10 from (128.242.4.59):
In Reply to: Farmall H missing posted by HaySam on February 25, 2003 at 11:00:27:
Is it missing on just one cylinder? If so remove plug wire from problem cylinder and exchange it with another wire from another cylinder. If problem moves it is the plug wire and if problem doesn't move, remove spark plug from problem cylinder and exchange it with another cylinder. If problem moves it is the spark plug. If no problems are found there, than it very well could be in the distributor cap or rotor. Since you say the compression is the same all across I assume that you meant it is adequate, and would rule out valve or ring problems. If it is missing randomly on different cylinders, then your problem would likely be in the points, condenser, or possibly in carburation. In this case it might be time for a general tune up, such as filing or replaceing points, adjusting carb settings, adjusting valve clearance, check timing, and so on. If just trying to pin point the problem you might try the things that do not require new parts, and is the easiest to do first in your process of elimination to find problem. Just some ideas.
Post A Followup
: Re: Re: Farmall H missing
