Re: Super C Steering Gear Lubrication
Posted by Haas on February 25, 2003 at 18:51:02 from (166.72.245.180):
In Reply to: Super C Steering Gear Lubrication posted by Bud on February 25, 2003 at 16:56:52:
If you did a good job on the seal replacement and the bearings and seal running surfaces are all good, then the steering gear should hold OK with the 80-90W gear oil. I've done two rebuilds on C steering gears and both have the gear oil in them and don't leak. On one of them, I had to use a speedy sleeve on the worm wheel shaft because the shaft worn and pitted and I did not think it would hold the oil.
Post A Followup
: Re: Re: Super C Steering Gear Lubrication
