Re: Pulled the valve cover on my H...yuck
Posted by Matt K. on February 26, 2003 at 06:41:24 from (204.23.231.133):
In Reply to: Pulled the valve cover on my H...yuck posted by mike in PA on February 25, 2003 at 22:30:35:
Mike,I had same problem with my H,I decided to
pull the oil pan also.I found 1-2 inches of nasty
stuff,plus the pick-up screen was 3/4 way plugged
I cleaned the top end out with diesel fuel and a
paint brush,check behind the push-rod cover also.
My advice is to change the oil and filter a few
times after you run it then. Matt
Post A Followup
: Re: Re: Pulled the valve cover on my H...yuck
