Re: C timing gears
Posted by Jim on February 26, 2003 at 07:40:30 from (198.247.178.217):
In Reply to: C timing gears posted by still learnin' on February 25, 2003 at 17:00:56:
You will need to take off the oil pan, oil pump, valve cover, rocker arm assembly, and
the push rods. Go buy some wood dowels a little bigger than the push rods sharpen them
so that the wedge in the lifters. lift the lifters off of the cam and hold the dowels up with
rubber bands going around two of the dowels. Now you can pull the camshaft.
Post A Followup
: Re: Re: C timing gears
