Re: C timing gears
Posted by REA on February 26, 2003 at 10:51:19 from (66.119.33.170):
In Reply to: C timing gears posted by still learnin' on February 25, 2003 at 17:00:56:
Hi Still Learning, You should be able to pull that gear off with your puller. I replaced one on my Farmall C about a year ago along with the distributor gear because the teeth were gone. They come off hard, so you may have to use a couple of bolts with nuts in behind it some how. The bad gear is made out of cast iron, drill 2 holes and tap them 180 degrees out, then put a bolt into them and jack the gear off. You may want to heat the new one in your wifes oven before placing it onto the shaft. Hope this helps! Bob
Post A Followup
: Re: Re: C timing gears
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
