Re: Do I need a keyed ignition switch on M for 12 volt conversion?
Posted by Tom W on February 26, 2003 at 11:32:45 from (63.191.176.85):
In Reply to: Do I need a keyed ignition switch on M for 12 volt conversion? posted by Bob G on February 26, 2003 at 10:57:59:
NO, push pull switch will work fine
Post A Followup
: Re: Re: Do I need a keyed ignition switch on M for 12 volt conversion?
