Re: Do I need a keyed ignition switch on M for 12 volt conversion?
Posted by Bob M on February 26, 2003 at 11:49:49 from (165.170.128.68):
In Reply to: Do I need a keyed ignition switch on M for 12 volt conversion? posted by Bob G on February 26, 2003 at 10:57:59:
Bob - You don't need a keyed ignition switch! However unless you have a self-exciting (the so-called "single wire") alternator, you will need to replace the existing ignition switch with a DPDT switch. You use one set of the DPDT switch contacts to send voltage to the alternator control terminal with the ignition "on", and the other set of switch contacts to ground the magneto when "off".
You could probably find a DPDT push-pull switch to replace existing ign switch, but it may be tough to find one. However a toggle type DPDT switch can be purchased at any Radio Shack for about $5.
Another option is to install a normally open oil pressure switch on the engine (one whose contacts CLOSE on sensing oil pressure) and use that to control the alternator. A little more complex, but lets you use the existing ignition switch.
Punch below for a diagram of the DPDT switch setup...
Post A Followup
: Re: Re: Do I need a keyed ignition switch on M for 12 volt conversion?
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
