Re: IH 141 self propled combine? What do you know?
Posted by Harold H on February 26, 2003 at 18:43:04 from (205.188.209.78):
In Reply to: IH 141 self propled combine? What do you know? posted by PoppinJohn720 on February 26, 2003 at 17:16:37:
A few specifications and comments on the McCormick 141 Harvester Thresher are as follows. Length of cutter bar 10', 12', or 14'; distance between divider points 10'8", 12'8", or 14'8"; tread 7'5 1/2"; wheel base 10'9", turning radius 8'6"; standard tires 13 x 26 and 6.00 x 16 (numerous tire sizes and tracks were available); gear transmission and variable speed drive; enclosed final drive; rasp bar or spike tooth cylinder; 595-1383 cyl rpm; width of seperator 32"; length of seperator surface 10'2"; 4 section straw walker; 29 7/16" chaffer sieve; 30" x 40" cleaning sieve; 6 cylinder IH engine; 240 cu in; 3 9/16" bore x 4 1/64" stroke; 60 hp @ 2200 rpm; overall length 26'7"; overall height 11'9 1/4"; 50 bu grain tank; weight with standard equipment 8860 lbs. The 141 was good combine but probably not the best on the market at the time. In our area while it was a current model it's main competors were the Case 120, JD 55, and MH 90. After it was introduced in 1955, in the mid and late 1950's, untill it was replaced in the 1960's by the 403, it had a reputation of being better than the Case 120, equal to or maby a little better than the JD 55, and not as good as the MH 90. Lots of people probably have different opinions on this ranking. It was built in several versions including "Rice Field Special" and "Hillside" models and there was a long list of optional equipment on each version. Hope this information helps you.
Harold H
Post A Followup
: Re: Re: IH 141 self propled combine? What do you know?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
