Farmall Tractors Discussion Board
Re: oil seal for Farmal M steering column
Posted by Robert on September 08, 1999 at 06:30:17 from (206.172.250.44):
In Reply to: oil seal for Farmal M steering column posted by Joe Roberts on September 07, 1999 at 19:31:01:
I replaced the seals on my 300 about 10 years ago.At that time they were still available from Case.I found out after that these seals rarely hold.You will find if you talk to people who have run these tractors that the steering boxes often ended up being filled with wheel bearing grease to provide lubrication that wouldn't seep out.While you have it apart consider giving the gear on the vertical shaft a1/2 turn so the worm works on teeth that haven't been used as much.
Post a Followup
: Re: Re: oil seal for Farmal M steering column
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
